28.06.2015, 02:19 | #1 (permalink) |
Автоматическая смена картинок в слайдере JS
Код:
(function(c, b, e) { var d = b.Modernizr; c.CBPFWSlider = function(f, g) { this.$el = c(g); this._init(f) }; c.CBPFWSlider.defaults = { speed: 500, easing: "ease" }; c.CBPFWSlider.prototype = { _init: function(f) { this.options = c.extend(true, {}, c.CBPFWSlider.defaults, f); this._config(); this._initEvents() }, _config: function() { this.$list = this.$el.children("ul"); this.$items = this.$list.children("li"); this.itemsCount = this.$items.length; this.support = d.csstransitions && d.csstransforms; this.support3d = d.csstransforms3d; var h = { WebkitTransition: "webkitTransitionEnd", MozTransition: "transitionend", OTransition: "oTransitionEnd", msTransition: "MSTransitionEnd", transition: "transitionend" }, k = { WebkitTransform: "-webkit-transform", MozTransform: "-moz-transform", OTransform: "-o-transform", msTransform: "-ms-transform", transform: "transform" }; if (this.support) { this.transEndEventName = h[d.prefixed("transition")] + ".cbpFWSlider"; this.transformName = k[d.prefixed("transform")] } this.current = 0; this.old = 0; this.isAnimating = false; this.$list.css("width", 100 * this.itemsCount + "%"); if (this.support) { this.$list.css("transition", this.transformName + " " + this.options.speed + "ms " + this.options.easing) } this.$items.css("width", 100 / this.itemsCount + "%"); if (this.itemsCount > 1) { this.$navPrev = c('<span class="cbp-fwprev"><</span>').hide(); this.$navNext = c('<span class="cbp-fwnext">></span>'); c("<nav/>").append(this.$navPrev, this.$navNext).appendTo(this.$el); var l = ""; for (var g = 0; g < this.itemsCount; ++g) { var f = g === this.current ? '<span class="cbp-fwcurrent"></span>' : "<span></span>"; l += f } var j = c('<div class="cbp-fwdots"/>').append(l).appendTo(this.$el); this.$navDots = j.children("span") } }, _initEvents: function() { var f = this; if (this.itemsCount > 1) { this.$navPrev.on("click.cbpFWSlider", c.proxy(this._navigate, this, "previous")); this.$navNext.on("click.cbpFWSlider", c.proxy(this._navigate, this, "next")); this.$navDots.on("click.cbpFWSlider", function() { f._jump(c(this).index()) }) } }, _navigate: function(f) { if (this.isAnimating) { return false } this.isAnimating = true; this.old = this.current; if (f === "next" && this.current < this.itemsCount - 1) { ++this.current } else { if (f === "previous" && this.current > 0) { --this.current } } this._slide() }, _slide: function() { this._toggleNavControls(); var g = -1 * this.current * 100 / this.itemsCount; if (this.support) { this.$list.css("transform", this.support3d ? "translate3d(" + g + "%,0,0)" : "translate(" + g + "%)") } else { this.$list.css("margin-left", -1 * this.current * 100 + "%") } var f = c.proxy(function() { this.isAnimating = false }, this); if (this.support) { this.$list.on(this.transEndEventName, c.proxy(f, this)) } else { f.call() } }, _toggleNavControls: function() { switch (this.current) { case 0: this.$navNext.show(); this.$navPrev.hide(); break; case this.itemsCount - 1: this.$navNext.hide(); this.$navPrev.show(); break; default: this.$navNext.show(); this.$navPrev.show(); break } this.$navDots.eq(this.old).removeClass("cbp-fwcurrent").end().eq(this.current).addClass("cbp-fwcurrent") }, _jump: function(f) { if (f === this.current || this.isAnimating) { return false } this.isAnimating = true; this.old = this.current; this.current = f; this._slide() }, destroy: function() { if (this.itemsCount > 1) { this.$navPrev.parent().remove(); this.$navDots.parent().remove() } this.$list.css("width", "auto"); if (this.support) { this.$list.css("transition", "none") } this.$items.css("width", "auto") } }; var a = function(f) { if (b.console) { b.console.error(f) } }; c.fn.cbpFWSlider = function(g) { if (typeof g === "string") { var f = Array.prototype.slice.call(arguments, 1); this.each(function() { var h = c.data(this, "cbpFWSlider"); if (!h) { a("cannot call methods on cbpFWSlider prior to initialization; attempted to call method '" + g + "'"); return } if (!c.isFunction(h[g]) || g.charAt(0) === "_") { a("no such method '" + g + "' for cbpFWSlider instance"); return } h[g].apply(h, f) }) } else { this.each(function() { var h = c.data(this, "cbpFWSlider"); if (h) { h._init() } else { h = c.data(this, "cbpFWSlider", new c.CBPFWSlider(g, this)) } }) } return this } })(jQuery, window); |
28.06.2015, 02:19 | |
Найдено много сходств с вашей темой Автоматическая система полива Автоматическая кормушка Автоматическая буровая установка Смена картинок по таймеру в Лазарусе Автоматическая смена скорости на сервере Автоматическая подсветка клавиатуры |
30.06.2015, 19:22 | #4 (permalink) |
Записей в дневнике: 4
Сказал(а) спасибо: 52
А чем помочь то , в чем вопрос ? Если проблемы, возьмите готовый c примерами(их кучи на том JQuery), или просто тупо не работает ? А jquery либу подключали ?
01.07.2015, 00:51 | #5 (permalink) |
Не точно описал проблему наверное. В слайдере нет автопрокрутки. Надо добавить.
15.07.2015, 22:15 | #7 (permalink) |
А причем тут
Вы дали голый скрипт, который сам по себе работать не будет К нему нужен сайт, "внедрение" этого этого скрипта в этот сайт с какими то настройками, наконец контент который этот скрипт должен крутить ... Ну скажу я вам, что да, поставил я этот скрипт у себя, у меня все работает , Вам это сильно поможет ? Дали бы ссылку на сайт можно было бы глянуть что там у вас не работает и как ... ошибку то js хоть не дает, firebug-ом или подобными средствами смотрели ? |
15.07.2015, 22:56 | #8 (permalink) | |
Ну если это поможет. |
15.07.2015, 23:31 | #10 (permalink) | |
