12.12.2009, 20:15 | #11 (permalink) |
Код:
begin SearchRootkit(true, true); SetAVZGuardStatus(true); TerminateProcessByName('c:\windows\system32\av_md.exe'); TerminateProcessByName('c:\documents and settings\Егор\av_md.exe'); DeleteFile('c:\documents and settings\Егор\av_md.exe'); DeleteFile('c:\windows\system32\av_md.exe'); DeleteFile('C:\Documents and Settings\Егор\av_md.exe'); DeleteFile('C:\WINDOWS\system32\av_md.exe'); DeleteFile('C:\WINDOWS\system32\drivers\unpr.sys'); DeleteFile('C:\Documents and Settings\Егор\Главное меню\Программы\Автозагрузка\updxsp32.exe'); DeleteFile('C:\WINDOWS\TEMP\~TM197.tmp'); DeleteFile('C:\WINDOWS\system32\189.tmp'); DeleteFile('C:\WINDOWS\system32\gebbccy.dll'); DeleteFile('C:\WINDOWS\system32\xm1985.dll'); DeleteFile('c:\windows\system32\gebbccy.dll'); DeleteFile('E:\autorun.inf'); DeleteFile('C:\WINDOWS\fonts\services.exe'); DeleteFile('c:\windows\system32\gebbccy.dll'); DeleteFile('E:\autorun.inf'); DeleteFile('C:\WINDOWS\system32\xm1985.dll'); DelBHO('{F4002052-AB29-4B33-8C8D-0E99084564EC}'); DeleteService('unpr'); RegKeyParamDel('HKEY_CURRENT_USER','Software\Microsoft\Windows\CurrentVersion\Run','av_md'); RegKeyParamDel('HKEY_USERS','.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run','av_md'); RegKeyParamDel('HKEY_USERS','S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Run','av_md'); RegKeyParamDel('HKEY_LOCAL_MACHINE','Software\Microsoft\Windows\CurrentVersion\Run','sysgif32'); RegKeyParamDel('HKEY_LOCAL_MACHINE','Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run','exec'); RegKeyParamDel('HKEY_LOCAL_MACHINE','Software\Microsoft\Windows\CurrentVersion\Run','14527'); RegKeyParamDel('HKEY_LOCAL_MACHINE','Software\Microsoft\Windows\CurrentVersion\Run','av_md'); RegKeyParamDel('HKEY_LOCAL_MACHINE','Software\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks','{F4002052-AB29-4B33-8C8D-0E99084564EC}'); RegKeyParamDel('HKEY_LOCAL_MACHINE','Software\Microsoft\Windows\CurrentVersion\Run','MsWerr'); RegKeyParamDel(' HKEY_USERS, .DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\Windows, Run ',' ',' '); RegKeyParamDel(' HKEY_USERS, .DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\Windows, Load ',' ',' '); RegKeyParamDel('HKEY_USERS, S-1-5-18\Software\Microsoft\Windows NT\CurrentVersion\Windows, Run ',' ',' '); RegKeyParamDel('HKEY_USERS, S-1-5-18\Software\Microsoft\Windows NT\CurrentVersion\Windows, Load ',' ',' '); RegKeyParamDel(' HKEY_CURRENT_USER, Software\Microsoft\Windows NT\CurrentVersion\Windows, Run ',' ',' '); RegKeyParamDel('HKEY_CURRENT_USER, Software\Microsoft\Windows NT\CurrentVersion\Windows, Load ',' ',' '); BC_ImportALL; ExecuteSysClean; BC_Activate; ExecuteRepair(13); RebootWindows(true); end. ---------- Добавлено в 18:15 ---------- Предыдущее сообщение было написано в 18:03 ---------- и еще это: Внимание !!! База поcледний раз обновлялась 18.08.2009 необходимо обновить базы при помощи автоматического обновления (Файл/Обновление баз) |
12.12.2009, 20:15 | |
Проблемы часто повторяются и ваша не исключение, вот схожие темы Коммутатор AlliedTelesyn CentreCOM FS708 Коммутатор управляемый D-Link DES-1228 Продам коммутатор (switch) D-Link DES-3526. Москва. продам Коммутатор Catalyst WS-C2924-XL-EN |
12.12.2009, 20:28 | #12 (permalink) |
сделал. перезагрузилось. залил
http://exfile.ru/71095 правда на компе стал виснуть инт. эксплорер - если конечно это что-то даёт). точнее псхелпфорум. вообще на нём не работает 0_оо ..поставил опер - таже проблема. браузеры виснут в общем ---------- Добавлено в 19:28 ---------- Предыдущее сообщение было написано в 19:18 ---------- базы обновил сделал всё заново |
12.12.2009, 20:41 | #13 (permalink) |
egorvldv, Запустите снова avz: Файл-Выполнить скрипт- в открывшееся окно внимательно вставьте текст:
Код:
begin SearchRootkit(true, true); SetAVZGuardStatus(true); BC_ImportALL; ExecuteSysClean; BC_Activate; ExecuteRepair(14); RebootWindows(true); end. после этого: гет.ехе Вы запускали? откат делали после запуска этой утилиты? если да, то повторите снова гет.ехе и стандартный скрипт №2. |
12.12.2009, 21:02 | #14 (permalink) |
гет.ехе запускал до этого ведь ещё. и перезагрузка была тогда сама по себе
..проблемы то не видно (только не работает ни один браузер) теперь при загрузке выскакивает окно об ошибке "Generic Host Process for Win32 Services" откат системы после запуска утилиты я не делал ---------- Добавлено в 20:02 ---------- Предыдущее сообщение было написано в 19:48 ---------- МЫ НЕ ИЗБАВИЛИСЬ ОТ ВИРУСА. Поменял время - назад на день вперёд. Он вылез опять. |
12.12.2009, 21:07 | #15 (permalink) | |
egorvldv, скрипт, что выше выполняли? по ошибке читаем здесь |
13.12.2009, 01:55 | #17 (permalink) |
Код:
begin SearchRootkit(true, true); SetAVZGuardStatus(true); DeleteFile('c:\windows\system32\DRIVERS\lcafrwol.s ys'); DeleteFile('70.103.101.103\aekgoprn.dll'); DeleteFile('\??\C2CAD972#4079#4fd3#A68D#AD34CC1210 74\b48dadf8.sys'); BC_ImportALL; ExecuteSysClean; BC_DeleteFile('70.103.101.103\aekgoprn.dll'); BC_DeleteFile('\??\C2CAD972#4079#4fd3#A68D#AD34CC1 21074\b48dadf8.sys'); BC_DeleteFile('c:\windows\system32\DRIVERS\lcafrwo l.sys '); BC_Activate; ExecuteRepair(2 ); ExecuteRepair(4 ); RebootWindows(true); end. ---------- Добавлено в 20:04 ---------- Предыдущее сообщение было написано в 19:32 ---------- egorvldv, запустите АВЗ в меню авз AVZGuard-включите AVZGuard-ждем 3 мин. затем перегружаем комп. снова запускаем авз и выполняем скрипт, что написан выше (http://pchelpforum.ru/f26/t17158/#post130714) ---------- Добавлено в 23:55 ---------- Предыдущее сообщение было написано в 20:04 ---------- egorvldv, воспользуйтесь файлом гет2.ехе взять можно отсюда http://pchelpforum.ru/f26/t17191/ и еще один момент: перед выполнением стандартного скрипта №2 обновите базы авз Файл-Обновление баз! |
14.12.2009, 18:40 | #18 (permalink) |
Помогите !
Вот лог http://slil.ru/28342765 ! Помогите, что делать дальше ????
14.12.2009, 19:07 | #19 (permalink) | |
комп перезагрузится. я пока составлю скрипт ---------- Добавлено в 16:49 ---------- Предыдущее сообщение было написано в 16:47 ---------- и обратите внимание: Внимание !!! База поcледний раз обновлялась 21.08.2009 необходимо обновить базы при помощи автоматического обновления (Файл/Обновление баз) ---------- Добавлено в 17:07 ---------- Предыдущее сообщение было написано в 16:49 ---------- Zloy08, Запустите снова avz: Файл-Выполнить скрипт- в открывшееся окно внимательно вставьте текст: Код:
begin SearchRootkit(true, true); SetAVZGuardStatus(true); DeleteFile('C:\Documents and Settings\Администратор\Главное меню\Программы\Автозагрузка\siszyd32.exe'); DeleteFile('C:\WINDOWS\system32\PavSRK.sys'); DeleteFile('C:\WINDOWS\system32\PavTPK.sys'); DeleteFile('C:\WINDOWS\TEMP\~TM174.tmp'); DeleteFile('C:\Program Files\Pivim Multibar\pivim.dll'); DelBHO('{1BB22D38-A411-4B13-A746-C2A4F4EC7344}'); DelBHO('{FCBCCB87-9224-4B8D-B117-F56D924BEB18}'); DeleteService('PavTPK.sys'); DeleteService('PavSRK.sys'); RegKeyParamDel('HKEY_LOCAL_MACHINE','Software\Microsoft\Windows\CurrentVersion\Run','sysgif32'); BC_ImportALL; ExecuteSysClean; BC_Activate; ExecuteRepair(5 ); ExecuteRepair(6 ); ExecuteRepair(8 ); RebootWindows(true); end. |
14.12.2009, 19:25 | #20 (permalink) |
При запуске вылетает ошибка (((
---------- Добавлено в 18:25 ---------- Предыдущее сообщение было написано в 18:23 ---------- при запуске вылетает ошибка ... |
