06.12.2011, 21:34 | #1 (permalink) |
Программирование на Pascal
06.12.2011, 21:34 | |
По данной тематике есть и другие темы Программирование Turbo Pascal. Программирование алгоритмов циклической структуры Программирование Программирование циклов в Си |
09.12.2011, 10:06 | #2 (permalink) | |
Сказал(а) спасибо: 340
Код:
VAR A,B:Array[1..4,1..4] of Byte; i,j,tA,tB,NA,NB:Byte; BEGIN Randomize; For i:=1 to 4 do For j:=1 to 4 do begin A[i,j]:=Random(20); B[i,j]:=Random(20); end; Writeln('Initial array A: Initial array B:'); For i:=1 to 4 do begin For j:=1 to 4 do write(A[i,j]:4); write(' '); For j:=1 to 4 do write(B[i,j]:4); writeln; end; Writeln; Write('Element of A to be replaced: Line - 1, Column - 2 '); Readln(tA); If tA=1 then Write('Number of line to be replaced: ') else Write('Number of column to be replaced: '); Readln(NA); Write('Element of B for replacement: Line - 1, Column - 2 '); Readln(tB); If tB=1 then Write('Number of line to be inserted into A: ') else Write('Number of column to be inserted into A: '); Readln(NB); If (tA=1) and (tB=1) then for j:=1 to 4 do A[NA,j]:=B[NB,j] else If (tA=1) and (tB=2) then for j:=1 to 4 do A[NA,j]:=B[j,NB] else If (tA=2) and (tB=1) then for j:=1 to 4 do A[j,NA]:=B[NB,j] else If (tA=2) and (tB=2) then for j:=1 to 4 do A[j,NA]:=B[j,NB]; Writeln; Writeln('Changed array A: Initial array B:'); For i:=1 to 4 do begin For j:=1 to 4 do write(A[i,j]:4); write(' '); For j:=1 to 4 do write(B[i,j]:4); writeln; end; Readln END. |
09.12.2011, 19:44 | #4 (permalink) |
