#1 (permalink) |
![]() Не запускается хоть убей! Wolf 1.32 win-x86 May 1 2002 ----- FS_Startup ----- Current search path: C:\Program Files (x86)\Return to Castle Wolfenstein\main\sp_pak5.pk3 (967 files) C:\Program Files (x86)\Return to Castle Wolfenstein\main\sp_pak4.pk3 (21 files) C:\Program Files (x86)\Return to Castle Wolfenstein\main\sp_pak3.pk3 (14 files) C:\Program Files (x86)\Return to Castle Wolfenstein\main\sp_pak2.pk3 (232 files) C:\Program Files (x86)\Return to Castle Wolfenstein\main\sp_pak1.pk3 (1342 files) C:\Program Files (x86)\Return to Castle Wolfenstein\main\pak0.pk3 (4775 files) C:\Program Files (x86)\Return to Castle Wolfenstein/main ---------------------- 7351 files in pk3 files execing default.cfg couldn't exec language.cfg execing wolfconfig.cfg execing autoexec.cfg Hunk_Clear: reset the hunk ok ...detecting CPU, found AMD w/ 3DNow! Bypassing CD checks ----- Client Initialization ----- Cmd_AddCommand: map_restart already defined ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' ): succeeded ...setting mode 8: 1280 1024 FS ...using colorsbits of 32 ...calling CDS: failed, bad mode ...trying next higher resolution: failed, bad mode ...restoring display settings ...registered window class ...created window@3,22 (1286x1052) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 8 ) ...65 PFDs found ...hardware acceleration found ...PIXELFORMAT 2 selected ...creating GL context: succeeded ...making context current: succeeded ...WARNING: fullscreen unavailable in this mode ...setting mode 8: 1280 1024 FS ...using colorsbits of 16 ...calling CDS: failed, bad mode ...trying next higher resolution: failed, bad mode ...restoring display settings ...window already present, CreateWindowEx skipped Initializing OpenGL driver ...WARNING: fullscreen unavailable in this mode ...shutting down QGL ...unloading OpenGL DLL ...assuming '3dfxvgl' is a standalone driver ...initializing QGL ...WARNING: missing Glide installation, assuming no 3Dfx available ...shutting down QGL ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- GLW_StartOpenGL() - could not load OpenGL subsystem |
Подскажу вам, что на форуме имеются аналогичные по содержанию обсуждения GLW_StartOpenGL - could not load OpenGL subsystem Не могу просматривать видео онлайн, подскажите что делать? Долго включается компьютер. Подскажите, что делать? Игры виснут, подскажите что делать? |
#2 (permalink) |
Попробуй в директории с игрой найти файлик wolfconfig.cfg и снести его нафиг (забэкапь на всякий случай!) Если запустится - эксперементируй с настройками, запоминай, после какой он опять сглючит, и заново удаляй этот файл.
