07.06.2014, 13:50 | #1 (permalink) |
Нужны блок-схемы к данным задачкам
const nmax=20; var a:array[1..nmax] of integer; i,n,k,k1,k2,k3:integer; begin clrscr; repeat write('n='); readln(n); until n in [1..nmax]; writeln('Последовательность :'); for i:=1 to n do begin a[i]:=-10+random(20); write(a[i]:4); end; writeln; write('k='); readln(k); k1:=0;k2:=0;k3:=0; for i:=1 to n do if a[i]>k then inc(k1) else if a[i]<k then inc(k2) else inc(k3); if k1=0 then writeln('Нету чисел больших ',k,'.') else writeln('Чисел больших ',k,' = ',k1,'.'); if k2=0 then writeln('Нету чисел меньших ',k,'.') else writeln('Чисел меньших ',k,' = ',k2,'.'); if k3=0 then writeln('Нету чисел равных ',k,'.') else writeln('Чисел равных ',k,' = ',k3,'.'); readkey; end. 2.Var N:LongInt; A:Array[1..10] of byte; i,k,min,max:byte; Begin Write('N (<2147482648) = '); Readln(N); k:=Trunc(Ln(N)/Ln(10))+1; for i:=1 to k do begin A[k-i+1]:=N mod 10; N:=N div 10; end; min:=10; max:=0; for i:=1 to k do begin if A[i]>max then max:=A[i]; if A[i]<min then min:=A[i]; end; for i:=1 to k do if (A[i]<>min) and (A[i]<>max) then write(A[i]); Readln; End. 3.var mass: array [1..100] of Real; i, j: integer; sum: Real; begin Randomize; sum := 0; for i := 1 to 100 do begin mass[i] := sqrt(Random(100)); if (i > 3) then begin for j := 2 to i do if (i mod j) = 0 then break; if (j = i) then begin WriteLn('mass[', i, '] = ', mass[i]:2:2); sum := sum + mass[i]; end end else begin WriteLn('mass[', i, '] = ', mass[i]); sum := sum + mass[i]; end; end; WriteLn('sum = ', sum:2:2); readln; end. 4.Var A:Array[1..5,1..3] of byte; i,j,n:byte; Ar_Mean:real; Begin Randomize; Ar_Mean:=0; n:=0; for i:=1 to 5 do begin for j:=1 to 3 do begin A[i,j]:=Random(21); Write(A[i,j]:4); Ar_Mean:=Ar_Mean+A[i,j]/15; end; writeln; end; writeln; writeln('Arithmetic Mean is ',Ar_Mean:0:3); writeln; for i:=1 to 5 do for j:=1 to 3 do if ((A[i,j] mod 2)=0) and (1.0*A[i,j]<Ar_Mean) then n:=n+1; writeln('n = ',n); Readln; End. 5.uses crt; const nmax=20; var a:array[1..nmax,1..nmax] of integer; n,i,j,mx:integer; begin clrscr; randomize; repeat write('Размер матрицы до ',nmax,' n='); readln(n); until n in [1..nmax]; writeln('Исходная матрица:'); for i:=1 to n do begin for j:=1 to n do begin a[i,j]:=random(50); if (j>=n-i+1)and(j>=i) then begin if(i=1)and(j=n) then mx:=a[i,j] else if a[i,j]>mx then mx:=a[i,j]; textcolor(12); end else textcolor(15); write(a[i,j]:3); end; writeln; end; textcolor(15); writeln('Максимальный элемент в выделенной области=',mx); readln end. 6.Var T:Array[1..30] of Integer; i:Integer; Begin Randomize; for i:=1 to 10 do T[i]:=-12+Random(11); for i:=11 to 20 do T[i]:=-5+Random(11); for i:=21 to 30 do T[i]:=Random(11); for i:=1 to 30 do write(T[i]:4); writeln; writeln; i:=0; Repeat i:=i+1; Until T[i]>0; Writeln('n = ',i); Readln End. 7.program massive uses crt; var a: array[1..10, 1..10] of word; i,j:word; begin for i:=1 to 10 do for j:=1 to 10 do readln(a[i,j]) j:=0; for i:=1 to 10 do j:=j+a[1,i]; for i:=1 to 10 do j:=j+a[i,1]; for i:=1 to 10 do j:=j+a[10,i]; for i:=1 to 10 do j:=j+a[i,10]; clrscr; write('Сумма значений составляет '); writeln(j); writeln('Нажмите любую кнопку для выхода'); readkey; end. 8.Const C=['a'..'z']+['A'..'Z']+['а'..'я']+['А'..'Я']+['0'..'9']; Var S:String; L,L_min,i:byte; Begin Writeln('Enter the string:'); Readln(S); L_min:=255; i:=0; Repeat while not (S[i] in C) do i:=i+1; L:=0; repeat L:=L+1; i:=i+1; until not (S[i] in C) or (i=Length(S)); if L<L_min then L_min:=L; Until i=Length(S); Writeln('Shortest word length is ',L_min); Readln End. 9.program xxx; uses crt; var S1, S2: string; i,k,n: integer; begin clrscr; writeln('S1'); readln(S1); writeln('S2'); readln(S2); n:=length(S1); i:=0; repeat k:= pos(S2, copy(S1, i+1, n)); if k <> 0 then i:=k; until k=0; if(i<>0) then delete(S1, i, length(S2)); writeln(S1); readln; end. 10.uses crt; var s : string; i : byte; begin clrscr; readln(s); i := 1; while (i<=length(s)) and (s[i] <> 'a') do inc(i); inc(i); if i<=length(s) then begin if not(odd(i)) then inc(i); while(i<=length(s)) do begin delete(s,i,1); inc(i); end; end; writeln('s=',s); readln; end. 11.function f(n : integer) : longint; begin if n <= 1 then f := 1 else f := n * f(n - 1); end; var n,m:integer; begin writeln('n= '); read(n); writeln('m= '); read(m); writeln((f(m)*f(m-n))/f(n)); end. 12.type point=record x:byte;y:byte;end; var a:array[1..4] of point; s:real; i:byte; function dlina(x1,y1,x2,y2:byte):real; begin dlina := SQRT(sqr(x2-x1)+sqr(y2-y1)); end; begin for i:=1 to 4 do begin writeln('Vvedite koord ',i,'to4ki'); Readln(a[i].x);Readln(a[i].y); end; for i:=1 to 3 do begin s:=s+dlina(a[i].x,a[i].y,a[i+1].x,a[i+1].y); end; writeln('Perimetr=',s:2:2); readln; end. 13.Program zap_14; Uses Crt; Const n=10; Type grafik = record Fio,dat1,dat2:string[20]; kol:integer; end; Var a : array[1..n] of grafik; i :byte; BEGIN ClrScr; for i:=1 to n do with a[I] do begin Writeln('Введите фамилию, имя, отчество '); Readln(fio); Writeln(' Введите дату начала отпуска'); Readln(dat1); Writeln(' Введите дату окончания отпуска'); Readln(dat2); Writeln(' Введите количество'); Readln(kol); End; Writeln('График отпусков'); for i:=1 to n do with a[I] do writeln (fio,' ',dat1,' ',dat2,' ',kol); Readln; end. 13.Const C=['б','в','г','д','ж','з','к','л','м','н','п','р','с ','т','ф','х','ц','ч','ш','щ']+ ['Б','В','Г','Д','Ж','З','К','Л','М','Н','П','Р','С ','Т','Ф','Х','Ц','Ч','Ш','Щ']; Var S:String; W:Set of Char; i:byte; L:Char; Begin W:=[]; Writeln('Enter the string:'); Readln(S); writeln; for i:=1 to Length(S) do if S[i] in C then W:=W+[S[i]]; for L:='б' to 'щ' do if L in W then write(L+' '); for L:='Б' to 'Щ' do if L in W then write(L+' '); Readln End. 14.var c: char; begin write(' Введите символ: '); readln(c); writeln(' Символьный код: ', byte(c)); writeln(' Предыдущий символ: ', pred(c)); writeln(Следующий символ ', succ(c)); readln 15. var x, y: real; begin write('x = '); readln(x); write('y = '); readln(y); writeln((y >= 2) and (x * x + y * y >= 16) and (x * x + y * y <= 36)); readln end. 16.Var a,b,h: real; Begin Write('Введите значение a = '); Readln(a); Write('Введите значение b = '); Readln(b); Write('Введите значение шага h = '); Readln(h); While a<=b do Begin Writeln(a:0:2,' ',2/3*(sin(1/3*a)):0:4); a:=a+h; end; Readln; end. 17.const m = 20; var i, max: integer; y: array [1..m] of integer; begin randomize; max := -12; writeln('Исходный массив'); for i := 1 to m do begin y[i] := random(21) - 10; write(y[i]:4); if not(odd(y[i])) and (y[i] > max) then max := y[i] end; writeln; writeln(‘Максимум = ', max); readln end. 18.var h: string; d: longint; i, z: integer; f: boolean; begin write(' шестнадцатеричное число= '); readln(h); if (length(h) = 0) or ((length(h) = 1) and (h[1] = '-')) then writeln(‘Число не было введено') else begin if h[1] <> '-' then z := 1 else begin z := -1; delete(h, 1, 1) end; if (length(h) > 8) or ((length(h) = 8) and (h[1] > 'E')) then writeln('Количество слишком большое') else begin for i := 1 to length(h) do begin if h[i] in ['a'..'f'] then h[i] := char(byte(h[i]) - byte('a') + byte('A')); f := not(h[i] in ['0'..'9', 'A'..'F']); if f then break end; if f then writeln('Это не шестнадцатеричное число') else begin d := 0; for i := 1 to length(h) do if h[i] in ['0'..'9'] then d := d * 16 - byte('0') + byte(h[i]) else d := d * 16 - byte('A') + byte(h[i]) + 10; writeln(Десятичное число = ', z * d) end; end end; readln end. 19. uses graph; var x,y,n,gd,gm,i,c: integer; begin write('звезд='); readln(N); gd:=detect; {инициализация графики} initgraph(gd,gm,''); randomize; for i:=1 to n do begin {создаются n точек} x:=random(640); {случайно распределенные} y:=random(480); {на экране 640*480 точек} c:=random(16); { выбор цвета} setcolor(c); circle(x,y,1) { оператор рисования окружности} end; readln end. 20.program kot; uses crt, graph; var gd,gm:integer; begin gd:=detect; initgraph(gd,gm, 'c:\tp7\bgi'); cleardevice; SetFillStyle(HatchFill,6); SetColor(6); FillEllipse(320,360,80,80); SetFillStyle(EmptyFill,0); FillEllipse(320,350,40,60); SetFillStyle(HatchFill,6); FillEllipse(320,245,40,40); FillEllipse(170,400,80,10); SetFillStyle(SolidFill,white); FillEllipse(305,245,10,15); FillEllipse(335,245,10,15); SetFillStyle(EmptyFill,0); FillEllipse(305,245,6,10); FillEllipse(335,245,6,10); SetColor(white); SetLineStyle(SolidLn, 0, ThickWidth); MoveTo(320,255); LineTo(312,265); LineTo(328,265); LineTo(320,255); LineTo(320,265); Line(315,265,270,265); Line(315,265,270,255); Line(315,265,270,275); Line(325,265,380,265); Line(325,265,380,255); Line(325,265,380,275); SetColor(6); MoveTo(280,230); LineTo(290,180); LineTo(300,210); LineTo(280,230); MoveTo(360,230); LineTo(350,180); LineTo(340,210); LineTo(360,230); Repeat Until KeyPressed; ReadKey; closegraph; end. |
07.06.2014, 13:50 | |
Эти темы ждут, пока вы их прочитаете Нужны схемы усилителей на TDA2005 и TDA2030AL Задачки на блок-схемы Какие элементы нужны для схемы? |
07.06.2014, 15:15 | #3 (permalink) |
