15.10.2013, 22:30 | #1 (permalink) |
Ход ферзя
Код программы: program Project6; {$APPTYPE CONSOLE} uses SysUtils, Windows; const n=8; type pointer=^node; node=record info,pair:array [1..n] of integer; nextointer; end; var f:_COORD; i,j:integer; x:array [1..n] of integer; a:array [1..n] of boolean; b:array [2..n+n] of boolean; c:array [1-n..n-1] of boolean; s,q,hointer; flag:boolean; ConHandle: THandle; function maseq(a,b:array of integer):boolean; begin maseq:=true; j:=1; for i:=n downto 1 do if x[i]<>q.info[j] then begin maseq:=false; Break; end else j:=j+1; end; procedure save(var sointer); begin if s=nil then begin new(s); for i:=1 to n do s.info[i]:=x[i]; end else begin q:=s; if q.next=nil then begin new(h); q.next:=h; h.next:=nil; for i:=1 to n do h.info[i]:=x[i]; end else while q.next<>nil do begin if maseq(q.info[i],x[i]) then begin for i:=1 to n do q.pair[i]:=x[i]; flag:=false; break; end else flag:=true; q:=q.next; end; if maseq(q.info[i],x[i]) then for i:=1 to n do q.pair[i]:=x[i]; if flag=true then begin new(h); q.next:=h; h.next:=nil; for i:=1 to n do h.info[i]:=x[i]; end; end; end; procedure writecol(i,j:integer; s:string); var TC:word; begin if odd(i+j) then tc:=0+7*16 else tc:=7+0*16; SetConsoleTextAttribute(ConHandle,tc); write(s,' '); end; procedure print(hointer); var k,r:integer; begin r:=1; While (h.next<>nil) do begin for i:=1 to n do begin j:=h.info[i]; for k:=1 to j-1 do writecol(i,k,' '); k:=j; writecol(i,k,'X '); for k:=j+1 to n do writecol(i,k,' '); SetConsoleTextAttribute(ConHandle,7+0*16); if i=1 then write(' ','Para',r,' ') else if r>9 then write(' ') else write(' '); j:=h.pair[i]; for k:=1 to j-1 do writecol(i,k,' '); k:=j; writecol(i,k,'X '); for k:=j+1 to n do writecol(i,k,' '); writeln; end; r:=r+1; h:=h.next; writeln(#10); end; end; procedure ferz(i:integer); var j:integer; begin for j:=1 to 8 do if a[j] and b[i+j] and c[i-j] then begin x[i]:=j; a[j]:=false; b[i+j]:=false; c[i-j]:=false; if i<n then ferz(i+1) else save(s); a[j]:=true; b[i+j]:=true; c[i-j]:=true; end; end; begin ConHandle := GetStdHandle( STD_OUTPUT_HANDLE ); f.X:=1200; f.Y:=1200; SetConsoleScreenBufferSize(ConHandle,f); for i:=1 to n do a[i]:=true; for i:=2 to n+n do b[i]:=true; for i:=1-n to n-1 do c[i]:=true; ferz(1); q:=s; print(q); readln; end. |
15.10.2013, 22:30 | |
Если хотите побыстрее решить проблему - полистайте аналогичные темы Ход ферзя. Pascal |
