19.06.2012, 13:51 | #1 (permalink) |
Требуется помощь в создании комментариев в листинге
ABCObjects, GraphABC; var pole: array [,] of ObjectABC; hod: char := 'X'; ok: ObjectABC; test:integer; const vin = 5; procedure picture(n, m: integer); var i, j: integer; begin for i := 0 to m - 1 do for j := 0 to n - 1 do if pole[i, j] = nil then pole[i, j] := new SquareABC(i * 30 + 40, j * 30 + 40, 30, clwhite); end; function vert(j: integer): boolean; var kz: integer;// i: integer; phod: char; begin if hod = 'X' then phod := 'O' else phod := 'X'; for i := 0 to length(pole, 0) - 1 do if pole[i, j].Text = phod then // подсчет строк begin inc(kz); if kz = 5 then begin result := true; exit; end; end else kz := 0; end; function gor(i: integer): boolean; var kz: integer; j: integer; phod: char; begin if hod = 'X' then phod := 'O' else phod := 'X'; for j := 0 to length(pole, 1) - 1 do if pole[i, j].Text = phod then // подсчет строк begin inc(kz); if kz = 5 then begin result := true; exit; end; end else kz := 0; end; function dig(i, j: integer): boolean; var kz: integer; phod: char; x := i; y := j; begin if hod = 'X' then phod := 'O' else phod := 'X'; while (x > 0) and (y > 0) do begin dec(x); dec(y); end; while (x <= length(pole, 0) - 1) and (y <= length(pole, 1) - 1) do begin if pole[x, y].Text = phod then // подсчет строк begin inc(kz); if kz = 5 then begin result := true; exit; end; end else kz := 0; inc(x); inc(y); end; x := i; y := j; while (x > 0) and (y < length(pole, 1) - 1) do begin dec(x); inc(y); end; kz:=0; while (x <= length(pole, 0) - 1) and (y > 0) do begin if pole[x, y].Text = phod then // подсчет строк begin inc(kz); if kz = 5 then begin result := true; exit; end; end else kz := 0; inc(x); dec(y); end; end; function proverka(i, j: integer): boolean; var x, y: integer; begin if vert(j) or gor(i) or dig(i, j) then begin result := true; exit; end; if i = length(pole, 0) - 1 then begin setlength(pole, length(pole, 0) + 1, length(pole, 1)); picture(length(pole, 1), length(pole, 0 )); end; if j = length(pole, 1) - 1 then begin setlength(pole, length(pole, 0), length(pole, 1) + 1); picture(length(pole, 1), length(pole, 0 )); end; if i = 0 then begin setlength(pole, length(pole, 0) + 1, length(pole, 1)); for x := length(pole, 0) - 2 downto 0 do for y := length(pole, 1) - 1 downto 0 do begin pole[x, y].Left := pole[x, y].Left + 30; pole[x + 1, y] := pole[x, y]; pole[x, y] := nil; end; picture(length(pole, 1), length(pole, 0 )); end; if j = 0 then begin setlength(pole, length(pole, 0), length(pole, 1) + 1); for y := length(pole, 1) - 2 downto 0 do for x := length(pole, 0) - 1 downto 0 do begin pole[x, y].top := pole[x, y].top + 30; pole[x, y + 1] := pole[x, y]; pole[x, y] := nil; end; picture(length(pole, 1), length(pole, 0 )); end; result := false; end; procedure rest; var n, m: integer; begin readln(n, m); pole := new ObjectABC[n, m]; setlength(pole, n, m); picture(m, n); end; procedure MyMouseDown(x, y, mb: integer); var ob: ObjectABC; i, j: integer; begin ob := ObjectUnderPoint(x, y); if ok = nil then begin if ob <> nil then if ob.text = '' then if hod = 'X' then begin ob.text := 'X'; hod := 'O'; end else begin ob.text := 'O'; hod := 'X'; end; if ob <> nil then if ob.Text <> '' then for i := 0 to Length(pole, 0) - 1 do for j := 0 to Length(pole, 1) - 1 do if pole[i, j].PtInside(x, y) then begin if proverka(i, j) then begin { if hod = 'O' then window.Title := 'Выйграли крестики' else window.Title := 'Выйграли нолики'; } ok := new SquareABC(window.Width div 2 - 50, window.Height div 2 - 50, 100, clwhite); if hod = 'O' then ok.Text := 'Выйграли крестики' else ok.Text := 'Выйграли нолики'; end; end; end; { if ob = ok then begin ok.Destroy;rest;end;} end; begin rest; OnMouseDown := MyMouseDown; end. |
19.06.2012, 13:51 | |
Встречал подобные посты ранее, вы можете их прочитать Нужна помощь в создании полного УНЧ Нужна помощь в создании усилителя на TDA 2003 Необходима помощь в создании алгоритма, выборе МК и программе Нужна помощь в создании устройства Помощь в создании сети клиент-сервер |
19.06.2012, 14:12 | #2 (permalink) | |
Сказал(а) спасибо: 340
21.06.2012, 12:23 | #3 (permalink) |
support
Записей в дневнике: 71
Сказал(а) спасибо: 166
Комментирую полностью листинг - дана программа, реализующая игру крестики-нолики средствами языка программирования PascalABC.
За более подробными комментариями обратитесь к разработчику листинга. |
