Помогите сделать блок-схему
program swimming_numbers;
{$mode objfpc}{$H+}
uses classes, sysutils;
var f :file of integer;
k:file of integer;
const size=1000;
type mas=array[1..size] of longint;
var a:mas;
n,l,count:integer;
procedure made_file;
begin
assign(f,'input.txt');
rewrite(f);
write('ўўҐ¤iвм Єi«мЄiбвм Ґ«Ґ¬Ґ*вiў: ');
read
; write(f,n);
write(' ўҐ«ҐзҐ*г *Ґ Ўi«миг пЄ®х ¬®¦** Ўг¤Ґ §¬i*ЁвЁ Ґ«Ґ¬Ґ*в: ');
read(l); write(f,l);
close (f);
end;
procedure Read_Data;
var i,l,n,k:integer;
begin
reset(f);
k:=filesize(f);
for i:=1 to k do
begin
read(f,a);
if i=1 then n:=a;
if i=2 then l:=a;
end;
writeln('ўўҐ¤iвм Їа®бвi зЁб«*');
for i:=1 to n do begin
read(a);
write(f,a);
end; end;
procedure quicksort(var a:mas; lo,hi:longint);
procedure sort(l,r:longint);
var i,j,x,y:longint;
begin
i:=l;
j:=r;
x:=a[(l+r)div 2];
repeat
while a<x do inc(i);
while x<a[j] do dec(j);
if i<=j then begin
y:=a;
a:=a[j];
a[j]:=y;
inc(i);
dec(j);
end;
until i>j;
if l<j then sort(l,j);
if i<r then sort(i,r);
end;
begin {quicksort};
sort(lo,hi);
end;
procedure solve;
var i:integer; j:longint;
begin
count:=0;
i:=1;
while i<=n do
begin
j:=i+1;
while j<=n and (a+2*l) do inc(j);
inc(count);
i:=j;
end;
end;
procedure write_data;
begin
assign(k,'output.txt');
write('ўўўҐ¤?вм Їа®бв? жЁдаЁ');
rewrite(k);
write(k,count);
close(k);
end;
begin
made_file;
read_data;
quicksort(a,1,n);
solve;
write_data;
end.
{$mode objfpc}{$H+}
k:file of integer;
const size=1000;
var a:mas;
n,l,count:integer;
begin
rewrite(f);
read
close (f);
end;
begin
reset(f);
k:=filesize(f);
for i:=1 to k do
begin
read(f,a);
if i=1 then n:=a;
if i=2 then l:=a;
end;
read(a);
write(f,a);
end; end;
begin
i:=l;
j:=r;
x:=a[(l+r)div 2];
repeat
if i<=j then begin
y:=a;
a:=a[j];
a[j]:=y;
inc(i);
dec(j);
end;
until i>j;
end;
begin {quicksort};
sort(lo,hi);
end;
procedure solve;
begin
count:=0;
i:=1;
while i<=n do
begin
j:=i+1;
inc(count);
i:=j;
end;
end;
begin
rewrite(k);
write(k,count);
close(k);
end;
begin
made_file;
read_data;
quicksort(a,1,n);
solve;
write_data;
end.
