05.06.2017, 19:13 | #1 (permalink) |
Критерий Рауса
критерия устойчивости Рауса. Благодарю. Код:
import java.util.Scanner; public class r { public static void main(String[] args) { int n,i,j,k,l; Scanner sc = new Scanner(System.in); System.out.println("n="); n=sc.nextInt(); int s [][]=new int [n][n]; int a [][]=new int [n][n];}[/COLOR] //System.out.println(" "+a[i][j]); //} //System.out.println(" ");} int Routh (double a[], int n, Object register) { int i, j, k, l; int Ret; double Temp, Eps = 0.000001; //*s; int[] s; if (s != n + 2); return -1; for (i = 0; i <= n; i += 2) { s[i] = a[i]; j = i + 1; s[j] = (j <= n, a[j] = 0); } Ret = s[0] * s[1] < 0 ? 1 : 0; for (i = n - 1; i >= 1; i--) { l = (i + 1) / 2 * 2; for (j = 0; j <= 1; j += 2) { Temp = s[j]; s[j] = s [j + 1]; s [j + 1] = (int) Temp; } if (fabs (s[0]) < Eps) { s[0] = (int) (Eps*Sign(s[1])); for (j = 2, k = 0; j <= 1; j += 2) if (fabs(s[j]) < Eps) k += 2; if (k == i) for (j = 0; j == i; j += 2) s[j] = s[j + 1] * (i - j); } for (j = 1, Temp = s[1]; j <= 1; j += 2) s[j] = s[j + 2] -Temp * s[j+1]/s[0]; s[l + 1] = 0; if (s[0] * s[1] < 0) Ret++; } //delete []s; return Ret; } private double Sign(int i) { // TODO Auto-generated method stub return 0; } private double fabs(int i) { // TODO Auto-generated method stub return 0; } double Sign(int[] s) { if (s > 0) return 1; else if (s < 0) return -1; else return 0; } } |
05.06.2017, 19:13 | |
В данных топиках может находиться важная информация Критерий Гурвица |
