27.07.2008, 18:11 | #11 (permalink) |
27.07.2008, 18:11 | |
По схожим топикам найдено следующее Жесткий диск Как отформатировать жесткий диск? |
28.07.2008, 12:24 | #14 (permalink) |
синий экран и вот че пишет
PROCESS1_INITIALIZATION_FAILED STOP 0x0000006B(0хС0000033,0х00000002,0х00000000,0х0000 0000) он даже винду не грузит тока начинает ее загружать бац до скорой встречи умер че делать не знаю помоги |
28.07.2008, 13:13 | #15 (permalink) |
STOP: 0x0000006B "Process1_ Initialization_Failed" error message when you try to upgrade to Windows XP
View products that this article applies to. Article ID : 330134 Last Review : July 11, 2006 Revision : 1.4 This article was previously published under Q330134 SYMPTOMS When you try to repair your Windows XP installation or when your computer first restarts after you upgrade to Windows XP, you may receive the following STOP error message on a blue-screen: A problem has been detected and Windows has been shut down to prevent damage to your computer. PROCESS1_INITIALIZATION_FAILED If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps: Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need. If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode. Technical information: *** STOP: 0x0000006B (0x0000003A, 0x00000002, 0x00000000, 0x00000000) Back to the top CAUSE This issue may occur if the Roxio GoBack program is installed in your computer. Note The GoBack program is also included with the Norton SystemWorks program. Back to the top RESOLUTION To resolve this issue, cancel Windows XP Setup, remove GoBack, and then restart Windows XP Setup. Back to the top WORKAROUND To work around this issue, disable GoBack when Windows XP Setup restarts the computer: Warning If you disable GoBack, all historical GoBack-related information is lost, and you cannot use GoBack to restore your computer to an earlier state. 1. Restart your computer, and then press the SPACEBAR when you receive the GoBack "Press SPACEBAR to repair problems or see other boot options" message. 2. On the GoBack Boot menu, click Disable GoBack, and then click Continue. 3. Click Yes to disable GoBack. 4. After you disable GoBack, click OK, and then click Continue. Back to the top MORE INFORMATION To obtain additional support information for the GoBack program, visit the following third-party Web site: http://www.symantec.com/techsupp/consumer.html (http://www.symantec.com/techsupp/consumer.html) Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information. The third-party products that are discussed in this article are manufactured by companies that are independent of Microsoft. Microsoft makes no warranty, implied or otherwise, regarding the performance or reliability of these products. |
19.09.2009, 20:23 | #17 (permalink) |
Проблема при загрузке Виндовс!
Стояла XP prof. всё было нормально. Решил поставить висту через загр. диск который шёл с компом. винчестер форматнулся, система установилась нормально. все работало...до первой перезагрузки! начинает грузиться внизу бежит белая полоска.....и слетает на синий экран! пробовал ставить висту ультимате, виндовс 7 - такая же фигня! работает до первой перезагрузки. Раньше ставил и висту, и ХР. Всё работало. Попробовал поставить ХР снова вчера вечером работало и перезагружалось. А сегодня утром опять перестало!
Что можно сделать?????? |
19.09.2009, 23:31 | #19 (permalink) |
fox1985,комп сноси в сервис ,че хош ,что-б совсем кони двинул с твоими экспирементами
