07.05.2014, 19:44 | #45 (permalink) |
оказываеться я этот тэст с самого начала нажал=))
07.05.2014, 20:29 | #48 (permalink) |
20:31:56 : Starting Victoria 4.47 Freeware (2013-02-20) , 4xCPU, 3817,67 MHz, Windows unknown NT found.
20:31:56 : Driver file not found. Please manually copy driver to your system32/driver directory 20:31:57 : Uknown error or driver not exist 20:31:57 : PORTTALK Error. Invalid driver handle 20:31:57 : PortTalk driver not installed! Available only API access 20:31:57 : API access enabled, device #1 20:32:07 : Get passport... OK 20:32:07 : 48bit access enabled 20:32:07 : Model: WDC WD1600JS-08NCB1; Capacity: 312581808 LBAs; SN: WD-WCANM8622908; FW: 10.02E01 20:33:30 : Get passport... OK 20:33:30 : Model: WDC WD1600JS-08NCB1; Capacity: 312581808 LBAs; SN: WD-WCANM8622908; FW: 10.02E01 20:34:18 : Get passport... OK 20:34:18 : Model: ST3160811AS; Capacity: 312581808 LBAs; SN: 6PT06FG6; FW: 3.AAE 20:34:18 : Get passport... OK 20:34:18 : Model: ST3160811AS; Capacity: 312581808 LBAs; SN: 6PT06FG6; FW: 3.AAE 20:34:35 : Get passport... OK 20:34:36 : Recallibration... OK 20:34:36 : Starting Reading, LBA=0..312581807, sequential access, timeout 10000ms 20:34:38 : Block 5632 Error: UNCR 20:35:06 : Block 3663104 Error: UNCR 20:35:31 : Block 6852608 Error: UNCR 20:35:38 : Block 7608064 Error: UNCR 20:35:41 : Block 7610368 Error: UNCR 20:35:43 : Block 7620352 Error: UNCR 20:36:07 : Block 10742784 Error: UNCR 20:36:30 : SMART ON command 20:36:30 : Get passport... OK 20:36:41 : Warning! Block start at 15696384 = 156 ms 20:37:30 : Block 22488576 Error: UNCR 20:41:04 : Command interrupted by user! 20:41:04 : ***** Scan results: Warnings - 1, errors - 8 ***** 20:41:10 : Get S.M.A.R.T. command... OK 20:41:10 : SMART status = GOOD 20:42:36 : Get passport... OK 20:42:36 : Recallibration... OK 20:42:36 : Starting Reading, LBA=0..312581807, sequential access, timeout 10000ms 20:42:38 : Block 5632 Error: UNCR 20:43:06 : Block 3663104 Error: UNCR 20:43:30 : Block 6852608 Error: UNCR 20:43:37 : Block 7608064 Error: UNCR 20:43:39 : Block 7610368 Error: UNCR 20:43:41 : Block 7620352 Error: UNCR 20:44:04 : Block 10742784 Error: UNCR 20:45:26 : Block 22488576 Error: UNCR 21:27:28 : ***** Scan results: Warnings - 0, errors - 8 ***** |
07.05.2014, 21:17 | #50 (permalink) | |
Нет такой платы.
Какой смысл проверять на другой МП? Зачем Вы меняете условия проверки???? Вы писали: Цитата:
2. Снимите джампер. Есть зависания? Новый smart из hddscan покажите. |
