Старый 21.10.2011, 19:33   #1 (permalink)
Vasilisk
Аватар для Vasilisk
Exclamation Если говорить по-ламерски, что это значит?
Что это значит, и как исправить.
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x69e7480b, pid=6656, tid=6756
# JRE version: 6.0_29-b11
# Java VM: Java HotSpot(TM) Client VM (20.4-b02 mixed mode windows-x86 )
# Problematic frame:
# C [atioglxx.dll+0xe4480b]
# If you would like to submit a bug report, please visit:
# HotSpot Virtual Machine Error Reporting Page
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x4cf88c00): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=6756, stack(0x4b5a0000,0x4b5f0000)]
siginfo: ExceptionCode=0xc0000005, writing address 0x00c01800
Registers:
EAX=0x00c01800, EBX=0x5d521000, ECX=0x00000008, EDX=0x00000000
ESP=0x4b5ef4ac, EBP=0x4b5ef4b4, ESI=0x5d521000, EDI=0x00c01800
EIP=0x69e7480b, EFLAGS=0x00010212
Top of Stack: (sp=0x4b5ef4ac)
0x4b5ef4ac: 00000400 00000000 4b5ef4e4 69e748b1
0x4b5ef4bc: 00c01800 5d521000 00000400 0247b958
0x4b5ef4cc: 00000000 00000050 5d521000 00c00000
0x4b5ef4dc: 00000100 5d521000 5cb01740 69738862
0x4b5ef4ec: 00c01800 5d521000 00000400 5cb01740
0x4b5ef4fc: 4f21a5b8 4f0052b0 00000100 00000400
0x4b5ef50c: 00000001 696eda30 00001800 04000000
0x4b5ef51c: 00000300 00000000 00000400 00000400
Instructions: (pc=0x69e7480b)
0x69e747eb: 4d 10 c1 e9 07 eb 06 8d 9b 00 00 00 00 66 0f 6f
0x69e747fb: 06 66 0f 6f 4e 10 66 0f 6f 56 20 66 0f 6f 5e 30
0x69e7480b: 66 0f 7f 07 66 0f 7f 4f 10 66 0f 7f 57 20 66 0f
0x69e7481b: 7f 5f 30 66 0f 6f 66 40 66 0f 6f 6e 50 66 0f 6f
Register to memory mapping:
EAX=0x00c01800 is an unknown value
EBX=0x5d521000 is an unknown value
ECX=0x00000008 is an unknown value
EDX=0x00000000 is an unknown value
ESP=0x4b5ef4ac is pointing into the stack for thread: 0x4cf88c00
EBP=0x4b5ef4b4 is pointing into the stack for thread: 0x4cf88c00
ESI=0x5d521000 is an unknown value
EDI=0x00c01800 is an unknown value
Stack: [0x4b5a0000,0x4b5f0000], sp=0x4b5ef4ac, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [atioglxx.dll+0xe4480b] atiPS+0x31eafb
C [atioglxx.dll+0xe448b1] atiPS+0x31eba1
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.GL11.nglTexSubImage2D(IIIIIIIILja va/nio/Buffer;IJ)V+0
j org.lwjgl.opengl.GL11.glTexSubImage2D(IIIIIIIILjav a/nio/ByteBufferV+62
j ur.a()V+473
j net.minecraft.client.Minecraft.k()V+165
j net.minecraft.client.Minecraft.run()V+168
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x4cff8000 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=6836, stack(0x4b9d0000,0x4ba20000)]
0x4d017400 JavaThread "Thread-10" daemon [_thread_blocked, id=6780, stack(0x51580000,0x515d0000)]
0x4d017000 JavaThread "Thread-9" daemon [_thread_blocked, id=6776, stack(0x514b0000,0x51500000)]
0x4cf84000 JavaThread "Thread-8" daemon [_thread_in_native, id=6772, stack(0x51420000,0x51470000)]
=>0x4cf88c00 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=6756, stack(0x4b5a0000,0x4b5f0000)]
0x4cf88400 JavaThread "Timer hack thread" daemon [_thread_blocked, id=6752, stack(0x4b510000,0x4b560000)]
0x02449800 JavaThread "DestroyJavaVM" [_thread_blocked, id=6664, stack(0x00380000,0x003d0000)]
0x4ab8b400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=6716, stack(0x4b330000,0x4b380000)]
0x4ab1fc00 JavaThread "AWT-Windows" daemon [_thread_in_native, id=6708, stack(0x4b030000,0x4b080000)]
0x4ab1f400 JavaThread "AWT-Shutdown" [_thread_blocked, id=6704, stack(0x4afa0000,0x4aff0000)]
0x4ab1c000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=6700, stack(0x4aeb0000,0x4af00000)]
0x0252c000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=6692, stack(0x4a9b0000,0x4aa00000)]
0x02527400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=6688, stack(0x4a920000,0x4a970000)]
0x02526000 JavaThread "Attach Listener" daemon [_thread_blocked, id=6684, stack(0x4a890000,0x4a8e0000)]
0x02523000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6680, stack(0x4a800000,0x4a850000)]
0x024f5c00 JavaThread "Finalizer" daemon [_thread_blocked, id=6676, stack(0x4a770000,0x4a7c0000)]
0x024f4800 JavaThread "Reference Handler" daemon [_thread_blocked, id=6672, stack(0x4a6e0000,0x4a730000)]
Other Threads:
0x024f0c00 VMThread [stack: 0x023b0000,0x02400000] [id=6668]
0x02540000 WatcherThread [stack: 0x4aa40000,0x4aa90000] [id=6696]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157248K, used 109364K [0x04550000, 0x0eff0000, 0x19aa0000)
eden space 139776K, 78% used [0x04550000, 0x0afdf280, 0x0cdd0000)
from space 17472K, 1% used [0x0dee0000, 0x0df1ddb0, 0x0eff0000)
to space 17472K, 0% used [0x0cdd0000, 0x0cdd0000, 0x0dee0000)
tenured generation total 349568K, used 155315K [0x19aa0000, 0x2f000000, 0x44550000)
the space 349568K, 44% used [0x19aa0000, 0x2324cf08, 0x2324d000, 0x2f000000)
compacting perm gen total 12800K, used 12720K [0x44550000, 0x451d0000, 0x48550000)
the space 12800K, 99% used [0x44550000, 0x451bc068, 0x451bc200, 0x451d0000)
No shared spaces configured.
Code Cache [0x02550000, 0x026c8000, 0x04550000)
total_blobs=873 nmethods=579 adapters=229 free_code_cache=32020224 largest_free_block=384
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files (x86)\Java\jre6\bin\javaw.exe
(.....сокращение.....)
0x6f0d0000 - 0x6f0d7000 C:\Windows\system32\midimap.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m -Dsun.java2d.noddraw=true -Dsun.java2d.d3d=false -Dsun.java2d.opengl=false -Dsun.java2d.pmoffscreen=false
java_command: net.minecraft.LauncherFrame
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Windows\system32;C:\Windows;C:\Wind ows\System32\Wbem;C:\Windows\System32\WindowsPower Shell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static
USERNAME=Антон
OS=Windows_NT
PROCESSOR_IDENTIFIER=AMD64 Family 16 Model 10 Stepping 0, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7600
CPU:total 6 (6 cores per cpu, 1 threads per core) family 16 model 10 stepping 0, cmov, cx8, fxsr, mmx, sse, sse2, sse3, popcnt, mmxext, 3dnow, 3dnowext, lzcnt, sse4a
Memory: 4k page, physical 4192440k(1167208k free), swap 8382980k(4492936k free)
vm_info: Java HotSpot(TM) Client VM (20.4-b02) for windows-x86 JRE (1.6.0_29-b11), built on Oct 3 2011 01:01:08 by "java_re" with MS VC++ 7.1 (VS2003)
time: Thu Oct 20 21:27:33 2011
elapsed time: 9 seconds
Vasilisk вне форума   Ответить с цитированием
Я думаю, что проблема получила свое решение по этим ссылкам
Что значит ваш ник?
Что это значит?
Старый 21.10.2011, 20:06   #2 (permalink)
Eli
TEHNARI.RU
Аватар для Eli
думаю проблема связана у тебя с библиотекой от видео карты
попробуй может Catalyst переустановить...( если конечно, не ошибаюсь - и может вообще нужно саму джава машину переустанавливать к примеру )
а после чего это началось?
Старый 21.10.2011, 20:08   #3 (permalink)
Vasilisk
Аватар для Vasilisk
Спасибо, попробую
Старый 21.10.2011, 20:20   #4 (permalink)
Eli
TEHNARI.RU
Аватар для Eli
Смотри - я точно не уверен что это и есть решение - но думаю что причина в этом...
а для обновление самой джава машины Java Runtime Environment заходим сюда Скачайте бесплатное программное обеспечение Java
Старый 24.10.2011, 06:23   #5 (permalink)
AlexZir
support
Аватар для AlexZir
Записей в дневнике: 71
Сказал(а) спасибо: 166
Драйвер видеокарты установите для х64, а не для x86
Плюс обязательно java обновите, версия, естественно, для x64
Часовой пояс GMT +4, время: 16:07.
