Старый 10.08.2011, 22:18   #11 (permalink)
Demonik
AVE Tehnari
Аватар для Demonik
sudo gedit /boot/grub/grub.cfg
далее этоти строки удаляете
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
insmod part_msdos
insmod ext2
set root='(hd0,msdos5)'
search --no-floppy --fs-uuid --set 1021ebd3-3e10-41f8-9bba-1631816ec4cc
linux16 /boot/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
а эти
### BEGIN /etc/grub.d/30_os-prober ###
menuentry "Windows 7 (loader) (on /dev/sda1)" {
insmod part_msdos
insmod ntfs
set root='(hd0,msdos1)'
search --no-floppy --fs-uuid --set 60ea8248ea821b04
chainloader +1
### END /etc/grub.d/30_os-prober ###
вырезаете и вставляете над этими
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Ubuntu, with Linux 2.6.35-25-generic' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-2.6.35-25-generic root=UUID=1021ebd3-3e10-41f8-9bba-1631816ec4cc ro quiet splash
initrd /boot/initrd.img-2.6.35-25-generic
menuentry 'Ubuntu, with Linux 2.6.35-25-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod part_msdos
insmod ext2
echo 'Loading Linux 2.6.35-25-generic ...'
linux /boot/vmlinuz-2.6.35-25-generic root=UUID=1021ebd3-3e10-41f8-9bba-1631816ec4cc ro single
echo 'Loading initial ramdisk ...'
### END /etc/grub.d/10_linux ###
вот так должно получиться
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
set default="0"
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
insmod vbe
insmod vga
insmod part_msdos
insmod ext2
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=640x480
load_video
insmod gfxterm
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
set locale_dir=($root)/boot/grub/locale
set lang=ru
insmod gettext
if [ "${recordfail}" = 1 ]; then
set timeout=-1
else
set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
insmod part_msdos
insmod ntfs
chainloader +1
recordfail
insmod part_msdos
insmod ext2
recordfail
insmod part_msdos
insmod ext2
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
Demonik вне форума   Ответить с цитированием
Пока вы ждете ответов в вашу тему, можете ознакомиться с этими темами
Выбор ноутбука из списка
Настройка загрузки операционной системы
Старый 10.08.2011, 22:19   #12 (permalink)
Demonik
AVE Tehnari
Аватар для Demonik
кстати этот параметр
set timeout=-1
это время ожидания выбора системы
поставьте 10 (это 10 секунд)
Старый 10.08.2011, 22:25   #13 (permalink)
Demonik
AVE Tehnari
Аватар для Demonik
и ещё тут
можно в кавычках отредактировать название системы
чтобы было написано просто
Windows 7 вместо Windows 7 (loader) (on /dev/sda1)
строчка будет такого вида
menuentry "Windows 7"
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu (recovery)' --class ubuntu --class gnu-linux --class gnu --class os {
Старый 11.08.2011, 00:10   #14 (permalink)
MoNeTa
Аватар для MoNeTa
Отлично! Все получилось, поменял местами нужные строчки, удалил ненужные мемтесты, названия не стал трогать, пусть остаютка какими были. Спасибо всем.
Может ввел кого-то в заблуждение. Файл grub.cfg нашел в партиции/разделе "Файловая система" а не "Зарезервированно ситемой".
MoNeTa вне форума   Ответить с цитированием
Старый 11.08.2011, 00:54   #15 (permalink)
Demonik
AVE Tehnari
Аватар для Demonik
он лежит тут
/boot/grub/grub.cfg
MoNeTa
кстати если надоест внешний вид простого grub ставьте Burg
http://www.sourceslist.eu/blog/linux...-been-so-easy/
ну а если просто хочется поменять цвет шрифта или фона, это делается правкой этих строк
напирмер красный надо
set menu_color_normal=red/black
set menu_color_highlight=black/light-red
Часовой пояс GMT +4, время: 01:53.
