#1 (permalink) |
Мой вам совет - попробуйте пока почитать схожие обсуждения Усилитель 2.1 Усилитель Усилитель для mp3 Усилитель 5:1 Усилитель 5:1 Усилитель 2.1 |
#2 (permalink) |
здесь подписаны выходы микрухи PGND2/TAB 1 power ground 2 and connection for heatsink
SDA 2 I 2 C-bus data input and output OUT3− 3 channel 3 negative output SCL 4 I 2 C-bus clock input OUT3+ 5 channel 3 positive output VP2 6 power supply voltage 2 to amplifier OUT1− 7 channel 1 negative output PGND1 8 power ground 1 OUT1+ 9 channel 1 positive output SVR 10 half supply voltage filter capacitor IN1 11 channel 1 input IN3 12 channel 3 input SGND 13 signal ground IN4 14 channel 4 input IN2 15 channel 2 input ACGND 16 AC ground OUT2+ 17 channel 2 positive output PGND3 18 power ground 3 OUT2− 19 channel 2 negative output VP1 20 power supply voltage 1 to amplifier OUT4+ 21 channel 4 positive output STB 22 standby or operating or mute mode select input OUT4− 23 channel 4 negative output PGND4 24 power ground 4 DIAG 25 diagnostic and clip detection output, active LOW RST 26 reset output SW2 27 antenna switch; supplies unregulated power to car aerial motor RESCAP 28 reset delay capacitor SW1 29 amplifier switch; supplies unregulated power to amplifier(s) REG1 30 regulator 1 output; supply for audio part of radio and CD player REG3 31 regulator 3 output; supply for signal processor part (mechanical digital) of CD player GND 32 combined voltage regulator, power and signal ground REG4 33 regulator 4 output; supply for mechanical part (mechanical drive) of CD player REG5 34 regulator 5 output; supply for display part of radio and CD player VP 35 power supply to voltage regulator BUCAP 36 connection for backup capacitor REG2 37 regulator 2 output; supply voltage to microcontroller |
