вот что вика показала.. Не страшно???1:22:40 : Warning! Main INI-file 'vcr40.ini' not found, and writen default sets!
1:22:40 : Starting Victoria 4.47 Freeware (2013-02-20) , 4xCPU, 2660,72 MHz, Windows unknown NT found.
1:22:40 : Select SECONDARY port: base=170h, alternative=376h
1:22:40 : Uknown error or driver not exist
1:22:40 : PORTTALK Error. Invalid driver handle
1:22:40 : PortTalk driver not installed! Available only API access
1:22:41 : API access enabled, device #1
1:22:51 : Get passport... OK
1:22:51 : [Warning] Invalid drive geometry!
1:22:51 : Model: MultipleCard Reader; Capacity: 1 LBAs
1:23:00 : Get passport... OK
1:23:00 : 48bit access enabled
1:23:00 : Model: SAMSUNG HM321HI; Capacity: 625142448 LBAs; SN: S26VJ9FB508810; FW: 2AJ10002
1:23:36 : Get S.M.A.R.T. command... OK
1:23:37 : SMART status = GOOD
1:23:54 : Get passport... OK
1:23:54 : Recallibration... OK
1:23:54 : Starting Reading, LBA=0..625142447, sequential access, timeout 10000ms
1:33:19 : Warning! Block start at 105854208 = 936 ms
1:33:19 : Warning! Block start at 105854464 = 218 ms
1:33:26 : Warning! Block start at 106987776 = 765 ms
1:33:26 : Warning! Block start at 106988032 = 203 ms
1:37:15 : Warning! Block start at 147226880 = 234 ms
1:42:22 : Warning! Block start at 199438592 = 218 ms
1:42:22 : Warning! Block start at 199438848 = 234 ms
1:42:34 : Warning! Block start at 200962048 = 265 ms
1:42:42 : Warning! Block start at 202182144 = 218 ms
1:43:00 : Warning! Block start at 205162240 = 250 ms
1:43:55 : Warning! Block start at 213939712 = 234 ms
1:44:32 : Warning! Block start at 220209664 = 219 ms
1:45:42 : Warning! Block start at 230892800 = 249 ms
1:45:44 : Warning! Block start at 231043840 = 218 ms
1:45:49 : Warning! Block start at 231511808 = 219 ms
1:50:13 : Warning! Block start at 271816192 = 234 ms
1:50:16 : Warning! Block start at 272246784 = 265 ms
1:50:27 : Warning! Block start at 273824768 = 359 ms
1:50:42 : Warning! Block start at 276153344 = 265 ms
1:55:30 : Warning! Block start at 321514752 = 203 ms
1:56:00 : Warning! Block start at 326035456 = 219 ms
1:56:30 : Warning! Block start at 330023680 = 250 ms
1:57:30 : Warning! Block start at 338357248 = 219 ms
1:59:00 : Warning! Block start at 350376448 = 250 ms
1:59:10 : Warning! Block start at 351771136 = 250 ms
1:59:12 : Warning! Block start at 352026368 = 234 ms
2:00:00 : Warning! Block start at 358819584 = 203 ms
2:00:30 : Warning! Block start at 363209984 = 344 ms
2:04:00 : Warning! Block start at 393276416 = 218 ms
2:04:48 : Warning! Block start at 398544128 = 203 ms
2:05:32 : Warning! Block start at 404530432 = 234 ms
2:06:07 : Warning! Block start at 408355072 = 218 ms
2:06:08 : Warning! Block start at 408467200 = 250 ms
2:08:00 : Warning! Block start at 423084544 = 234 ms
2:10:30 : Warning! Block start at 442988800 = 234 ms
2:10:32 : Warning! Block start at 443191296 = 219 ms
2:11:39 : Warning! Block start at 451987200 = 328 ms
2:13:04 : Warning! Block start at 462992128 = 390 ms
2:13:06 : Warning! Block start at 463164672 = 296 ms
2:13:10 : Warning! Block start at 463553536 = 203 ms
2:13:16 : Warning! Block start at 464192256 = 203 ms
2:13:18 : Warning! Block start at 464432896 = 219 ms
2:14:00 : Warning! Block start at 469639680 = 203 ms
2:15:00 : Warning! Block start at 477312768 = 266 ms
2:16:30 : Warning! Block start at 488723712 = 219 ms
2:17:30 : Warning! Block start at 495997696 = 312 ms
2:17:44 : Warning! Block start at 497626880 = 234 ms
2:20:30 : Warning! Block start at 517419008 = 296 ms
2:24:00 : Warning! Block start at 541744640 = 203 ms
2:25:00 : Warning! Block start at 548400128 = 218 ms
2:25:32 : Warning! Block start at 551788800 = 281 ms
2:27:34 : Warning! Block start at 565089536 = 328 ms
2:28:02 : Warning! Block start at 568078080 = 328 ms
2:28:04 : Warning! Block start at 568259584 = 281 ms
2:29:30 : Warning! Block start at 577327872 = 328 ms
2:32:40 : Warning! Block start at 596352768 = 203 ms
2:33:00 : Warning! Block start at 598214144 = 281 ms
2:33:19 : Warning! Block start at 599886848 = 1045 ms
2:33:19 : Warning! Block start at 599887104 = 374 ms
2:33:26 : Warning! Block start at 600475136 = 406 ms
2:33:26 : Warning! Block start at 600475392 = 219 ms
2:36:18 : Warning! Block start at 616783104 = 250 ms
2:37:45 : ***** Scan results: Warnings - 62, errors - 0 *****
Жить будет.Не страшно???
С этим да тут косяк не продумали.невозможно посмотреть/оставить коммент (может не нашёл) и макс разрешение 720р
что за бред??Доступ с вашего IP-адреса временно ограничен
Мы обнаружили на нём подозрительную активность, нарушающую работоспособность Avito.
Это могло быть вызвано следующими причинами:
вы обновляли одну страницу множество раз;
вы открывали большое количество вкладок со ссылками на наш сайт;
ваш компьютер заражен вирусом и создаёт опасность заражения других пользователей (обязательно проверьте свой компьютер на наличие вирусов);
c вашего адреса генерируется (возможно не вами) мощный поток данных, мешающий другим пользователям получать услуги в полном объёме.
Если вы считаете, что ваш адрес заблокирован по ошибке, напишите нам.
В обращении обязательно укажите:
ваш IP-адрес (его можно посмотреть на internet.yandex.ru);
название интернет-провайдера;
город проживания.
