Старый 22.02.2009, 16:09   #1 (permalink)
pencjo
По умолчанию Совместимость памяти PC3200 400MHz 512MB
Извиняюсь(если мой вопрос был задан-некоректно,т.к. ответа на него небыло.),задам по другому. Вот данные моего Процессора,Матери и Планок памяти:
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type Intel Celeron-S, 1200 MHz (12 x 100)
CPU Alias Tualatin, A80530
CPU Stepping tA1
Instruction Set x86, MMX, SSE
Original Clock 1200 MHz
L1 Code Cache 16 KB
L1 Data Cache 16 KB
L2 Cache 256 KB (On-Die, ATC, Full-Speed)
CPU Physical Info:
Package Type 370 Pin FC-PGA2
Package Size 4.95 cm x 4.95 cm
Transistors 44 million
Process Technology 6M, 0.13 um, CMOS
Die Size 80 mm2
Core Voltage 1.475 / 1.5 V
I/O Voltage 3.3 V
Typical Power 20 / 21 W @ 1.20 GHz
Maximum Power 29.9 / 32.1 W @ 1.20 GHz
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
Motherboard ID 10/09/2001-i815-47B27X-IA69RT3CC-00
Motherboard Name Chaintech 6OIA3T
Front Side Bus Properties:
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 100 MHz
Effective Clock 100 MHz
Bandwidth 800 MB/s
Memory Bus Properties:
Bus Type SDR SDRAM
Bus Width 64-bit
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Motherboard Physical Info:
CPU Sockets/Slots 1
Expansion Slots 3 PCI, 1 AGP, 1 CNR
RAM Slots 2 DIMM
Integrated Devices Audio
Form Factor Micro ATX
Motherboard Size 190 mm x 240 mm
Motherboard Chipset i815EP
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: SpecTek (128 MB PC133 SDRAM) ]
Memory Module Properties:
Module Name SpecTek
Serial Number None
Module Size 128 MB (1 rank, 4 banks)
Module Type Unbuffered
Memory Type SDRAM
Memory Speed PC133 (133 MHz)
Module Width 64 bit
Module Voltage LVTTL
Error Detection Method None
Refresh Rate Reduced (7.8 us)
Memory Timings:
@ 133 MHz 3.0-3-3-6 (CL-RCD-RP-RAS)
@ 83 MHz 2.0-2-2-4 (CL-RCD-RP-RAS)
Так вот-могу ли я на свой комп поставить планку PC3200 400MHz 512MB - взамен своих двух по 128MB?
Жду ответа от знающих людей,заранее Благодарен(и прошу Извинить за мою неопытность.)
Последний раз редактировалось pencjo; 22.02.2009 в 21:40
pencjo вне форума   Ответить с цитированием
Подскажу вам, что можно прочитать похожие обсуждения
Совместимость Asus P5GD1 с новой видео картой ATI Radeon HD5670 512Mb
Совместимость оперативной памяти
Старый 23.02.2009, 00:39   #2 (permalink)
pan111
Судя по описанию
http://www.nix.ru/autocatalog/mother...oATX_9563.html
PC133 512MB - потолок, т.е. ответ нет
pan111 вне форума   Ответить с цитированием
Старый 23.02.2009, 01:32   #3 (permalink)
pencjo
Благодарю за наглядный ответ.
Старый 11.04.2009, 13:02   #4 (permalink)
pencjo
В посте выше есть ссылка на сайт где можно посмотреть данные(конкретной) материнки. На интересующую меня,я все нашел. А вот по этой M/B CHAINTECH CT-7AIA5E SocketA(462) <VIA8363> AGP+CMI8738 UDMA100 MicroATX 2SDRAM / Мат.платы CHAINTECH / Материнские Платы / каталог оборудования там мало данных,мне хотелось-бы знать-какие типы процессоров она поддерживает? какой максимальный обьем памяти? Может кто подскажет-где можно это посмотреть?
Старый 11.04.2009, 13:46   #5 (permalink)
Maga
Заведующий MAGAзином
Аватар для Maga
Все данные надо смотреть на официльном сайте производителя. Добро пожаловать в Chaintech Ишете нужную мать, и смотрите.
Старый 11.04.2009, 16:42   #6 (permalink)
ilevar
Аватар для ilevar
Сообщение от pencjo Посмотреть сообщение
Мать из той же оперы что и в #1. А PC3200 400MHz 512MB не поставить - гнезда на память разные. И тип памяти тоже
ilevar вне форума   Ответить с цитированием
Старый 12.04.2009, 11:21   #7 (permalink)
pencjo
Спасибо, Добро пожаловать в Chaintech у этой матери насколько я понял-максимально поддерживаемая память 1GB? И процессоры-Duron или Athlon(только почему они со знаком вопроса?)
сайт производителя
Часовой пояс GMT +4, время: 14:23.
