Помогите расшифровать файл PhP
  • Автор темы Автор темы aleks870
aleks870
8 Ноя 2012
Код:
<?php //0046a
if(!extension_loaded('ionCube Loader')){$__oc=strtolower(substr(php_uname(),0,3));$__ln='ioncube_loader_'.$__oc.'_'.substr(phpversion(),0,3).(($__oc=='win')?'.dll':'.so');if(function_exists('dl')){@dl($__ln);}if(function_exists('_il_exec')){return _il_exec();}$__ln='/ioncube/'.$__ln;$__oid=$__id=realpath(ini_get('extension_dir'));$__here=dirname(__FILE__);if(strlen($__id)>1&&$__id[1]==':'){$__id=str_replace('\\','/',substr($__id,2));$__here=str_replace('\\','/',substr($__here,2));}$__rd=str_repeat('/..',substr_count($__id,'/')).$__here.'/';$__i=strlen($__rd);while($__i--){if($__rd[$__i]=='/'){$__lp=substr($__rd,0,$__i).$__ln;if(file_exists($__oid.$__lp)){$__ln=$__lp;break;}}}if(function_exists('dl')){@dl($__ln);}}else{die('The file '.__FILE__." is corrupted.\n");}if(function_exists('_il_exec')){return _il_exec();}echo('Site error: the file <b>'.__FILE__.'</b> requires the ionCube PHP Loader '.basename($__ln).' to be installed by the website operator. If you are the website operator please use the <a href="http://www.ioncube.com/lw/">ionCube Loader Wizard</a> to assist with installation.');exit(199);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Из этого всего я понял только то, что должен появиться какой-то лоадер с ID ionCube Loader
И то, если правильно понял
