14.03.2019, 14:54 | #1 (permalink) |
Немного не умею присваивать переменные на php sql
<html> <style> #items { margin-top: 100px; } .item { float: left; width: 50px; height: 50px; margin: 1px; } .red { background: #cf2624; } .blue { background: #2478cf; } .green { background: #24cf7c; } .orange { background: #cf7c24; } .yellow { background: #f1e81f; } </style> <body> <select id="filter"> <option value="item">все</option> <option value="red">красный</option> <option value="blue">синий</option> </select> <div id="items"> <div class="item red">1</div> <div class="item blue">2</div> </div> <script type="text/javascript"> var filter_select_el = document.getElementById('filter'); var items_el = document.getElementById('items'); filter_select_el.onchange = function() { console.log(this.value); var items = items_el.getElementsByClassName('item'); for (var i=0; i<items.length; i++) { if (items[i].classList.contains(this.value)) { items[i].style.display = 'block'; } else { items[i].style.display = 'none'; } } }; </script> </body> </html> Вот мой код <html> <body> <select id="filter"> <option value="item">Все</option> <?php include_once("db.php"); $result = mysql_query(" SELECT DISTINCT nazvanie FROM tablica "); while($row = mysql_fetch_assoc($result)) {?> <option value="????????????????????????"><?php echo $row['nazvanie']; ?></option> <?php }?> </select> <div id="items "> <?php include_once("db.php"); $name = "item "; $result = mysql_query(" SELECT nazvanie FROM tablica "); while($row = mysql_fetch_assoc($result)) {?> <div class="????????????????????????"> <input type="text" name="nazvanie" value="<?php echo $row['nazvanie']; ?> " readonly="readonly"> </div> <?php }?> </div> <script type="text/javascript"> var filter_select_el = document.getElementById('filter'); var items_el = document.getElementById('items'); filter_select_el.onchange = function() { console.log(this.value); var items = items_el.getElementsByClassName('item'); for (var i=0; i<items.length; i++) { if (items[i].classList.contains(this.value)) { items[i].style.display = 'block'; } else { items[i].style.display = 'none'; } } }; </script> </body> </html> |
14.03.2019, 14:54 | |
Проблема частая, на форуме уже создавались схожие обсуждения Топ-материнку под AMD. Не умею выбрать :( Переменные резисторы |
mysql, php, sql |
