20.11.2019, 01:39 | #1 (permalink) |
Логи в Virtualbox
И что тут можно понять? 00:00:53.191888 /PDM/Queue/E1000-Rcv/cbItem 16 bytes 00:00:53.191890 /PDM/Queue/E1000-Xmit/AllocFailures 0 times 00:00:53.191892 /PDM/Queue/E1000-Xmit/Flush 0 calls 00:00:53.191894 /PDM/Queue/E1000-Xmit/FlushLeftovers 0 times 00:00:53.191896 /PDM/Queue/E1000-Xmit/Insert 0 calls 00:00:53.191899 /PDM/Queue/E1000-Xmit/cItems 1 count 00:00:53.191901 /PDM/Queue/E1000-Xmit/cbItem 16 bytes 00:00:53.191903 /PDM/Queue/Keyboard/AllocFailures 0 times 00:00:53.191905 /PDM/Queue/Keyboard/Flush 0 calls 00:00:53.191907 /PDM/Queue/Keyboard/FlushLeftovers 0 times 00:00:53.191909 /PDM/Queue/Keyboard/Insert 0 calls 00:00:53.191911 /PDM/Queue/Keyboard/cItems 64 count 00:00:53.191913 /PDM/Queue/Keyboard/cbItem 16 bytes 00:00:53.191916 /PDM/Queue/Mouse/AllocFailures 0 times 00:00:53.191918 /PDM/Queue/Mouse/Flush 0 calls 00:00:53.191920 /PDM/Queue/Mouse/FlushLeftovers 0 times 00:00:53.191922 /PDM/Queue/Mouse/Insert 0 calls 00:00:53.191924 /PDM/Queue/Mouse/cItems 128 count 00:00:53.191927 /PDM/Queue/Mouse/cbItem 40 bytes 00:00:53.191929 /PDM/Queue/Mouse_1/AllocFailures 0 times 00:00:53.191931 /PDM/Queue/Mouse_1/Flush 0 calls 00:00:53.191933 /PDM/Queue/Mouse_1/FlushLeftovers 0 times 00:00:53.191935 /PDM/Queue/Mouse_1/Insert 0 calls 00:00:53.191937 /PDM/Queue/Mouse_1/cItems 128 count 00:00:53.191939 /PDM/Queue/Mouse_1/cbItem 40 bytes 00:00:53.191942 /PGM/CPU0/cA20Changes 2 times 00:00:53.191944 /PGM/CPU0/cGuestModeChanges 146478 times 00:00:53.191947 /PGM/ChunkR3Map/Mapped 182 count 00:00:53.191949 /PGM/ChunkR3Map/Unmapped 0 count 00:00:53.191951 /PGM/ChunkR3Map/c 182 count 00:00:53.191953 /PGM/ChunkR3Map/cMax 512 count 00:00:53.191956 /PGM/LargePage/Recheck 0 times 00:00:53.191958 /PGM/LargePage/Refused 0 times 00:00:53.191960 /PGM/LargePage/Reused 0 times 00:00:53.191964 /PGM/Page/cAllPages 460103 count 00:00:53.191967 /PGM/Page/cBalloonedPages 0 count 00:00:53.191969 /PGM/Page/cHandyPages 64 count 00:00:53.191971 /PGM/Page/cLargePages 0 count 00:00:53.191973 /PGM/Page/cLargePagesDisabled 0 count 00:00:53.191975 /PGM/Page/cMonitoredPages 0 count 00:00:53.191977 /PGM/Page/cPrivatePages 97025 count 00:00:53.191980 /PGM/Page/cPureMmioPages 37 count 00:00:53.191982 /PGM/Page/cReadLockedPages 0 count 00:00:53.191984 /PGM/Page/cReusedSharedPages 0 count 00:00:53.191986 /PGM/Page/cSharedPages 0 count 00:00:53.191988 /PGM/Page/cWriteLockedPages 0 count 00:00:53.191990 /PGM/Page/cWrittenToPages 0 count 00:00:53.191993 /PGM/Page/cZeroPages 363041 count 00:00:53.191995 /PGM/ShMod/Check 0 ticks/call ( 0 ticks, 0 times, max 0, min -1) 00:00:53.191998 /PGM/cRelocations 0 times 00:00:53.192001 /PROF/CPU0/EM/Capped 0 ticks/call ( 0 ticks, 0 times, max 0, min -1) 00:00:53.192004 /PROF/CPU0/EM/ForcedActions 62515 times 00:00:53.192007 /PROF/CPU0/EM/Halted 180 times 00:00:53.192009 /PROF/CPU0/EM/RAWTotal 0 times 00:00:53.192011 /PROF/CPU0/EM/REMTotal 0 times 00:00:53.192014 /PROF/CPU0/EM/Total 98825898796 ticks/call ( 98825898796 ticks, 1 times, max 98825898796, min 98825898796) 00:00:53.192019 /PROF/CPU0/VM/Halt/Block 872753 ns/call ( 2425382687 ticks, 2779 times, max 11925149, min 1796) 00:00:53.192023 /PROF/CPU0/VM/Halt/BlockInsomnia 0 ns/call ( 0 ticks, 0 times, max 0, min -1) 00:00:53.192026 /PROF/CPU0/VM/Halt/BlockOnTime 0 ns/call ( 0 ticks, 0 times, max 0, min -1) 00:00:53.192029 /PROF/CPU0/VM/Halt/BlockOverslept 0 ns/call ( 0 ticks, 0 times, max 0, min -1) 00:00:53.192032 /PROF/CPU0/VM/Halt/Timers 2312 ns/call ( 11226424 ticks, 4855 times, max 2275838, min 521) 00:00:53.192036 /PROF/CPU0/VM/Halt/Yield 0 ns/call ( 0 ticks, 0 times, max 0, min -1) 00:00:53.192039 /Public/Net/E1k0/BytesReceived 0 bytes 00:00:53.192041 /Public/Net/E1k0/BytesTransmitted 0 bytes 00:00:53.192043 /REM/TbFlushCount 0 times 00:00:53.192046 /REM/TbPhysInvldCount 0 times 00:00:53.192048 /REM/TlbFlushCount 98 times 00:00:53.192050 /SELM/LoadHidSel/GstReadErrors 0 times 00:00:53.192053 /SELM/LoadHidSel/NoGoodGuest 0 times 00:00:53.192055 /TM/CPU/00/cNsExecuting 8746528434 ns 00:00:53.192058 /TM/CPU/00/cNsHalted 2439061890 ns 00:00:53.192060 /TM/CPU/00/cNsOther 20032052940 ns 00:00:53.192063 /TM/CPU/00/cNsTotal 31217643264 ns 00:00:53.192065 /TM/CPU/00/cPeriodsExecuting 5460352 count 00:00:53.192067 /TM/CPU/00/cPeriodsHalted 180 count 00:00:53.192070 /TM/CPU/00/pctExecuting 79 % 00:00:53.192072 /TM/CPU/00/pctHalted 0 % 00:00:53.192074 /TM/CPU/00/pctOther 20 % 00:00:53.192076 /TM/CPU/pctExecuting 79 % 00:00:53.192078 /TM/CPU/pctHalted 0 % 00:00:53.192081 /TM/CPU/pctOther 20 % 00:00:53.192083 /TM/MaxHzHint 0 Hz 00:00:53.192085 /TM/R0/1nsSteps 5229 times 00:00:53.192088 /TM/R3/1nsSteps 5132 times 00:00:53.192090 /TM/TSC/offCPU0 0 ticks 00:00:53.192093 /TM/VirtualSync/CurrentOffset 494010 ns 00:00:53.192095 /VUSB/0/cUrbsInPool 0 count 00:00:53.192098 ********************* End of statistics ********************** 00:00:53.203539 NAT: zone(nm:mbuf_cluster, used:0) 00:00:53.203828 NAT: zone(nm:mbuf_packet, used:0) 00:00:53.203833 NAT: zone(nm:mbuf, used:0) 00:00:53.203884 NAT: zone(nm:mbuf_jumbo_pagesize, used:0) 00:00:53.204165 NAT: zone(nm:mbuf_jumbo_9k, used:0) 00:00:53.204301 NAT: zone(nm:mbuf_jumbo_16k, used:0) 00:00:53.204373 NAT: zone(nm:mbuf_ext_refcnt, used:0) 00:00:53.212029 Changing the VM state from 'DESTROYING' to 'TERMINATED'. |
20.11.2019, 01:39 | |
Возможно, ответ на ваш вопрос можно найти тут HELP VirtualBox VirtualBox Virtualbox VirtualBox- VirtualBox |
