16.11.2009, 12:16 | #22 (permalink) | |
Код:
' *************************************************************************** ' * ' * Title : LCD Thermometer LM35.bas ' * Version : 1.0 ' * Last Updated : 17.04.2006 ' * Target : AT Mega8 ' * Author : www.avrprojects.net ' * Program code : BASCOM AVR ' * Hardware req. : LM35 ' * Description : read analog value from LM 35 temperature sensor, show the result on a LCD ' * display with bar-graph ' *************************************************************************** $regfile = "M8def.dat" ' use the Mega8 $crystal = 10000000 Deflcdchar 0 , 32 , 32 , 31 , 31 , 31 , 31 , 32 , 32 'delenie Deflcdchar 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 'palka sprava Deflcdchar 2 , 16 , 16 , 16 , 16 , 16 , 16 , 16 , 16 'palka sleva Deflcdchar 3 , 16 , 16 , 31 , 31 , 31 , 31 , 16 , 16 'palka sleva i delenie Deflcdchar 4 , 1 , 1 , 31 , 31 , 31 , 31 , 1 , 1 'palka sprava i delenie Deflcdchar 5 , 32 , 32 , 28 , 28 , 28 , 28 , 32 , 32 'polovina delenia Deflcdchar 6 , 1 , 1 , 29 , 29 , 29 , 29 , 1 , 1 'palka sprava i polovina delenia Deflcdchar 7 , 16 , 16 , 28 , 28 , 28 , 28 , 16 , 16 'palka sleva i polovina delenia Config Lcdpin = Pin , Db4 = Portd.3 , Db5 = Portd.2 , Db6 = Portd.1 , Db7 = Portd.0 , E = Portd.6 , Rs = Portd.7 Config Lcd = 20 * 4 Config Adc = Single , Prescaler = Auto , Reference = Avcc 'config ADC Start Adc Dim W As Word , Perc As Word , Volt As Word , Volt_d As Byte , Channel As Byte , I As Byte , Cols As Byte , Cols_d As Byte , T As Byte , Cols_1 As Byte Cls Cursor Off Locate 3 , 1 Lcd "0" Locate 3 , 5 Lcd "10" Locate 3 , 10 Lcd "20" Locate 3 , 15 Lcd "30" Locate 3 , 19 Lcd Chr(223) ; "C" Do W = Getadc(0) Volt = W * 5 Volt_d = Volt Mod 10 Volt = Volt / 10 Locate 1 , 1 Lcd Volt ; "," ; Volt_d Cols = Volt / 2 Cols_d = Volt Mod 2 Cols_1 = Cols + 1 Locate 2 , 1 If Cols = 0 Then If Cols_d = 0 Then Lcd Chr(2) Else Lcd Chr(7) End If Else Lcd Chr(3) End If For I = 2 To 20 T = I Mod 5 If T = 0 Then If Cols_1 = I Then If Cols_d = 1 Then Lcd Chr(6) Else Lcd Chr(1) End If End If If Cols < I And Cols_1 < I Then Lcd Chr(1) If Cols >= I And Cols_1 > I Then Lcd Chr(4) Else If Cols_1 = I Then If Cols_d = 1 Then Lcd Chr(5) Else Lcd Chr(32) End If End If If Cols < I And Cols_1 < I Then Lcd Chr(32) If Cols >= I And Cols_1 > I Then Lcd Chr(0) End If Next I Waitms 1000 Loop End |
04.03.2010, 09:06 | #24 (permalink) |
Записей в дневнике: 73
Сказал(а) спасибо: 885
Без стабилизатора никак. А на пятивольтовом стабилизаторе собрана схема на первой картинке.
04.03.2010, 10:03 | #25 (permalink) |
04.03.2010, 10:07 | #26 (permalink) |
Нет, не будет. В этой схеме включения микросхема регулирует выходное напряжение в пределах 5 - 11.5 вольт.
18.06.2010, 14:07 | #29 (permalink) |
Подскажите пожалуйста.
Я паять умею, но в деталях не очень разбираюсь. Пошел в радиомагазин, а там продавец сказал, что не указана мощность всех деталей и поэтому не знает что мне нужно. Не могли бы подсказать мощности всех деталей в 1-ой схеме? (ну та, которая здесь Простой реобасс. (Моддинг для начинающих)) |
18.06.2010, 14:20 | #30 (permalink) |
Резисторы мощностью 0.25 ватта.
