29.12.2011, 00:53 | #1 (permalink) |
При установке сайта возникла ошибка
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM' at line 24You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM' at line 41You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM' at line 5Table 'auto.auto_ws_city' doesn't existYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM' at line 7You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM' at line 6Table 'auto.auto_ws_dop' doesn't existYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM' at line 5Table 'auto.auto_ws_marka' doesn't existYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM' at line 6 помогите разобраться в этой проблеме |
29.12.2011, 00:53 | |
Я думаю, что хорошо было бы поискать решение вопроса в схожих темах При установке Windows ошибка Stop:0x0000007b Ошибка доступа при установке SP3 |
29.12.2011, 02:22 | #5 (permalink) |
есть такой вариант: везде где используется 'TYPE=MyISAM' заменить на 'ENGINE = MyISAM'
29.12.2011, 23:16 | #6 (permalink) |
